IAU Circulars (IAUCs) - циркуляры МАС - 09/2010
Сообщение Tikhon » 07 дек 2010, 13:02
1 September 2010
IAU Electronic Telegram No.2432
SUPERNOVA 2010hf IN MCG +09-11-21
T. Boles, Coddenham, England, reports the discovery of an apparent
supernova (mag 18.3) on unfiltered CCD images taken on Aug. 31.114 and 31.894
with a 0.35-m reflector. The new object is located at R.A. = 6h37m19s.77
+/- 0s.02, Decl. = +56o22'57".8 +/- 0".2 (equinox 2000.0), which is
approximately 5".6 west and 11".8 north of the center of MCG +09-11-21.
Nothing is present at this position on Boles's images from 2010 Mar. 2 and
2009 Sept. 25 (limiting mag 19.5) or on Digitized Sky Survey plates from 1991
Feb. 8 (limiting red mag 20.5) and 1991 Dec. 12 (limiting blue mag 21.0).
2010 September 1 (CBET 2432) Daniel W. E. Green
Re: IAU Circulars (IAUCs) - циркуляры МАС - 09/2010
2 September 2010
IAU Electronic Telegram No.2434
SUPERNOVA 2010hg IN NGC 3001
L. A. G. Monard, Pretoria, S. Africa, reports his discovery of an
apparent supernova (magnitude 15.0) on several unfiltered CCD images taken
on Sept. 1.143 UT at the Bronberg Observatory. The new object, which was
confirmed at mag 14.7 via images taken on Sept. 2.138, is located at R.A. =
9h46m13s.7, Decl. = -30d27'13".3 (equinox 2000.0), or 64" west and 58" south
of the core of the nearby type-Sbc galaxy NGC 3001; 2010hg is located in or
near one of the outer spiral arms. Nothing is seen at this position on
Digitized Sky Survey images (limiting red mag 20.5) or on the previous image
of this galaxy taken at the Bronberg Observatory on Aug. 2.690 (limiting mag
18.0) or on earlier images from there.
2010 September 2 (CBET 2434) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:03
2 September 2010
IAU Electronic Telegram No.2435
SUPERNOVA 2010hh IN NGC 6524
Further to CBET 2396, L. Jewett, S. B. Cenko, W. Li, and A. V. Filippenko,
University of California, report the LOSS discovery of an apparent supernova
in NGC 6524 (= UGC 11079) on unfiltered KAIT images:
2010hh Sept. 1.22 17 59 18.38 +45 52 32.2 18.3 38".7 E, 42".4 S
S. Nakano, Sumoto, Japan, reports the independent discovery by Koichi
Itagaki (Teppo-cho, Yamagata) of 2010hh at mag 18.1 on a unfiltered CCD
frames (limiting mag 21.0) taken on Sept. 2.588 UT using a 0.60-m f/5.7
reflector (+ Bitran BT-214E camera), the position end figures for 2010hh
measured as 18s.37 +/- 0s.01, 32".0 (offset 38" east, 42" south). Itagaki
adds that nothing is visible at this position on the Digitized Sky Survey.
Additional magnitudes for 2010hh: 2007 Aug. 15, [19.5 (Itagaki); 2010 July
30.33, [19.6 (KAIT); Aug. 29.544, [19.0 (Itagaki); Sept. 1.595, 18.4
(Itagaki; pre-discovery); Sept. 2.21, 18.0 (KAIT). Itagaki's discovery
images has been posted at http://k-itagaki.chicappa.jp:80/images/psn6524.jpg.
2010 September 2 (CBET 2435) Daniel W. E. Green
3 September 2010
IAU Electronic Telegram No.2436
SUPERNOVA 2010hi IN NGC 6621
Ron Arbour, South Wonston, Hants, U.K., reports his discovery of an
apparent supernova (mag 18.0) on unfiltered CCD images taken on Sept.
1.893 (limiting mag 19.2) and 2.883 UT using a 0.4-m f/5 Newtonian
reflector (+ Starlight Xpress camera) in the course of his supernova
patrol. The new object is located at R.A. = 18h13m00s.76, Decl. =
+68d21'53".4 (equinox 2000.0), which is 30" east and 4" north of the
center of the galaxy NGC 6621. Nothing is visible at this position on
Digitized Sky Survey plates from 1989 Sept. 1 (limiting blue mag 20.8)
and 1993 Aug. 12 (limiting red mag 19.5). Arbour adds that four further
confirming images were obtained by Tom Boles between Sept. 1.9400 and
1.9435. Following posting on the Central Bureau's unconfirmed-objects
webpage, S. Nakano (Sumoto, Japan) forwards information from a pre-
discovery unfiltered CCD image of 2010hi obtained by Koichi Itagaki
(Teppo-cho, Yamagata, Japan) using a 0.60-m f/5.7 reflector, yielding
position end figures 00s.66 +/- 0s.04, 53".0 +/- 0".1 and the following
magnitudes: 2008 June 12.685, [19.5; Sept. 1.608, 18.7; 2.565, 18.5
(limiting mag 19.5).
2010 September 3 (CBET 2436) Daniel W. E. Green
3 September 2010
IAU Electronic Telegram No.2437
SUPERNOVAE 2010hf IN MCG +09-11-21
G. H. Marion and P. Challis, Harvard-Smithsonian Center for Astrophysics
(CfA), on behalf of the CfA Supernova Group, report that a low-signal-to-noise
spectrum (range 360-740 nm) of 2010hf (cf. CBET 2432), obtained on Sept. 2 UT
by P. Berlind with the F. L. Whipple Observatory 1.5-m telescope (+ FAST),
shows 2010hf to be a type-IIb supernova. Cross-correlation with a library of
supernova spectra using the "Supernova Identification" code (SNID; Blondin
and Tonry 2007, Ap.J. 666, 1024) provides the best fit to spectra from SN
1993J obtained a few days after maximum light.
2010 September 3 (CBET 2437) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:04
3 September 2010
IAU Electronic Telegram No.2438
SUPERNOVA 2010hj IN PGC 67413
A. J. Drake, S. G. Djorgovski, A. Mahabal, M. J. Graham, and R. Williams,
California Institute of Technology; R. H. McNaught and G. Garradd, Australian
National University; S. Howerton, Arkansas City, KS, U.S.A., J. L. Prieto,
Carnegie Observatories; M. Catelan, Pontificia Universidad Catolica de Chile;
E. C. Beshore and S. M. Larson, Lunar and Planetary Laboratory, University of
Arizona; and E. Christensen, Gemini Observatory, report the discovery of an
apparent supernova in unfiltered Siding Spring Survey (SSS) images:
2010hj Aug. 4.61 21 49 09.84 -59 02 23.2 17.1 5".5 W, 8".2 S
Nothing was visible at this position on an SSS image from 2009 Oct. 1.50 UT
(limitiing mag 18.9), but 2010hj was detected again in SSS images on Aug.
29.59 (no magnitude provided). The host galaxy appears to be PGC 67413 = ESO
145-G16. Joseph Brimacombe, Cairns, Australia, reports that ten stacked 600-s
CCD images (limiting magnitude 20) taken remotely with a 32-cm RCOS telescope
(+ STL6K camera + clear filter) at the Macedon Ranges Observatory near
Melbourne, Australia, on Aug. 29.727 show the new object to be at mag 18.3
and located approximately 7" west and 7" south of the presumed host-galaxy
nucleus. Another stacked image (seven 1200-s frames; limiting magnitude 20),
taken by Brimacombe on Sept. 2.636 with a 40-cm RCOS telescope (+ U16 camera
+ red filter) at the Coral Towers Observatory (Cairns), yields mag 18.6 for
2010hj; the Sept. 2 stacked image has been posted at the following website
URL: http://www.flickr.com/photos/43846774@N02/4952444311/.
2010 September 3 (CBET 2438) Daniel W. E. Green
3 September 2010
IAU Electronic Telegram No.2439
SUPERNOVA 2010hk IN UGC 2802
J. Newton and T. Puckett report the discovery of an apparent supernova
(mag 17.6) on unfiltered CCD images (limiting mag 19.2) taken with a 0.40-m
reflector at Portal, AZ, U.S.A., on Sept. 2.44 UT in the course of the
Puckett Observatory Supernova Search. The new object, which was confirmed on
Sept. 3.44 at mag 17.6 on images (limiting mag 19.1) taken by Puckett with the
0.40-m reflector at Portal, is located at R.A. = 3h37m52s.61, Decl. =
+4o56'52".2 (equinox 2000.0), which is 26".4 east and 3".9 south of the center
of UGC 2802. Nothing is visible at this position on images taken by Puckett
on 2009 July 28 (limiting mag 19.2).
2010 September 3 (CBET 2439) Daniel W. E. Green
4 September 2010
IAU Electronic Telegram No.2440
SUPERNOVA 2010hl IN MCG +10-24-122
supernova (mag 17.5) on an unfiltered CCD image taken on Sept. 2.904 UT with a
0.35-m reflector. The new object is located at R.A. = 17h16m33s.34 +/- 0s.01,
Decl. = +57o52'08".3 +/- 0".1 (equinox 2000.0), which is approximately 2".0
west and 0".4 south of the center of MCG +10-24-122. Nothing is present at
this position on Boles's images from 2010 July 18 and May 10 (limiting mag
19.5) or on Digitized Sky Survey plates from 1993 Apr. 22 (limiting red mag
20.5) and 1991 Apr. 16 (limiting blue mag 21.0). Boles also measured
magnitude V = 17.4 for 2010hl on Sept. 3.1754 using an image taken with a
0.61-m Cassegrain reflector at the Sierra Stars Observatory, Alpine County,
California (limiting mag 20.5). He has posted images at the following
website URL: http://www.supernova.myzen.co.uk/images/.
2010 September 4 (CBET 2440) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:05
4 September 2010
IAU Electronic Telegram No.2441
2010 September 4 (CBET 2441) Daniel W. E. Green
4 September 2010
IAU Electronic Telegram No.2442
SUPERNOVA 2010hm IN UGC 12687
Further to CBET 2435, K. Lin, M. Kandrashoff, S. B. Cenko, W. Li, and A.
V. Filippenko, University of California, report the LOSS discovery of an
apparent supernova on unfiltered KAIT images:
2010hm Sept. 2.40 23 35 18.58 +12 55 31.9 18.9 14".8 E, 4".5 N
Additional KAIT magnitudes for 2010hm in UGC 12687: a co-added image from
June 21-July 22, [20.2; Sept. 3.38, 19.0.
2010 September 4 (CBET 2442) Daniel W. E. Green
4 September 2010
IAU Electronic Telegram No.2443
S. Nakano, Sumoto, Japan, reports that K. Kadota (Ageo, Japan) obtained
a co-added image (limiting mag 18.6) of 2010hh (cf. CBETs 2435, 2440) from
twelve 120-s unfiltered CCD frames taken around Sept. 3.675 UT with a 0.25-m
f/5 reflector (+ SBIG ST-9E camera), yielding mag 17.7 and position R.A. =
17h59m18s.39, Decl. = +45d52'32".1 (equinox 2000.0).
J. M. Silverman, J. Choi, A. V. Filippenko, and F. J. D. Serduke,
University of California, Berkeley, report that inspection of a CCD spectrum
(range 340-970 nm), obtained on SepT. 3 UT with the 3-m Shane reflector (+
Kast) at Lick Observatory, shows that 2010hh is a type-Ia supernova near
maximum brightness. After removal of the host-galaxy recession velocity of
5698 km/s (Falco et al. 1999, PASP 111, 438), the absorption minimum of the
Si II 635.5-nm line is found to be blueshifted by about 12600 km/s. The Si
II line at 597 nm is quite strong, as is Ti II absorption around 420-430 nm,
suggesting that 2010hh is subluminous like SN 1991bg (e.g. Filippenko et al.
1992, AJ 104, 1543), though perhaps not quite as extreme.
2010 September 4 (CBET 2443) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:06
5 September 2010
IAU Electronic Telegram No.2444
SUPERNOVA 2010hn
Denis Vida, on behalf of the "La Sagra Sky Survey (LSSS) Supernova Search
Team" (which includes also Filip Novoselnik, Ivica Skokic, Robert Gregic, David
Gostinski, Anton Aladenic, Salvador Sanchez, Jaime Nomen, Reiner Stoss, Bill
Yeung, Juan Rodriguez, and Miguel Hurtado), reports the discovery of an
apparent supernova (magnitude 17.5) on three CCD images (limiting mag about
20.0) taken on Aug. 7.012, 7.025, and 7.038 UT with a 0.45-m telescope. The
new object is located at R.A. = 21h43m19s.14, Decl = -15d03'19".6 (equinox
2000.0), which is 10".5 east and 0".5 south of the nucleus of the presumed
host galaxy. Additional approximate magnitudes for 2010hn (from unfiltered
images unless otherwise noted): 1987 Oct. 18.43, [22 (Digitized Sky Survey,
red plate); 2010 Aug. 2.062, 17.2 (LSSS); 15.970, 18.2 (LSSS); 19.346, 19.8
(J. Brimacombe, Cairns, Australia; remotely using a 50-cm RCOS telescope
+ STL11K camera from New Mexico Skies Observatory near Mayhill, NM, U.S.A.);
19.981, 18.7 (LSSS); 27.399, 19.9 (Brimacombe; measured by Vida). The LSSS
image from Aug. 2 has been posted (with the red DSS image on the right) at
website URL http://img834.imageshack.us/img834/5729 ... 012952.png.
2010 September 5 (CBET 2444) Daniel W. E. Green
5 September 2010
IAU Electronic Telegram No.2445
SUPERNOVA 2010ho
Simone Leonini, Siena, Italy, reports the discovery by G. Guerrini and
himself of an apparent supernova (mag about 16.6) on an unfiltered CCD image
(limiting mag about 19.0) taken on 2010 Sept. 4.01 UT during the Montarrenti
Observatory Supernovae Search program using a 0.53-m f/7.8 Ritchey-Chretien
telescope (+ Apogee Alta U47 CCD camera). The new object, which is present
at mag about 16.7 also in eight unfiltered CCD images (limiting mag about
18.8) taken with the same telescope during Sept. 4.948-4.958, is located at
R.A. = 23h19m10s.24, Decl. = +9d11'54".4 (equinox 2000.0), which is 3" east
and 12" north of the nucleus of the galaxy PGC 1361264. Nothing is visible
at this position in two images taken on 2009 Oct. 11.941 (limiting mag about
18.8), and 2010ho does not appear on Palomar Sky Survey infrared, red, and
blue plates (1995 Sept. 18, F plate; 1951 Aug. 9, J plate; 1990 July 28, N
plate, limiting mag 19.5). The discovery image of 2010ho is posted at URL
http://www.jacopobaldi.it/dati/psn%20PGC1361264.jpg, and the confirmation
image at http://www.jacopobaldi.it/dati/confirma ... 361264.jpg.
2010 September 5 (CBET 2445) Daniel W. E. Green
6 September 2010
IAU Electronic Telegram No.2446
SUPERNOVA 2010hp IN MCG -02-01-52
M. Miluzio, Padua University; and E. Cappellaro, Istituto Nazionale di
Astrofisica, Osservatorio Astronomico di Padova, report their discovery of an
apparent supernova in the course of the European Southern Observatory "Infrared
Supernova Search in Starburst Galaxies" performed with the HAWK-I instrument
at the Very Large Telescope (VLT). The new object was first detected on a
K-band image obtained on July 21.26 UT at magnitude K = 17.1 (limiting mag K
= 19) and was confirmed on an image taken on Aug. 7.39 at magnitude K = 16.9
(limiting K magnitude 20). The presumed supernova is located at R.A. =
0h18m50s.01, Decl.= -10o21'40".6 (equinox 2000.0), which is 2".6 west and 2".7
north of the center of MCG -02-01-52. Nothing is visible at this position on
K-band images taken on 2009 Aug. 25.41 (limiting K magnitude 20). No optical
images have been obtained yet. An identification map is posted at the
following website URL: http://tinyurl.com/35ukbxh.
2010 September 6 (CBET 2446) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:07
6 September 2010
IAU Electronic Telegram No.2447
SUPERNOVAE 2010hk AND 2010ho
(CfA), on behalf of the CfA Supernova Group, report on spectroscopic
observations (range 340-740 nm) of 2010hk (cf. CBET 2439) obtained on Sept. 4
UT by P. Berlind and of 2010ho (cf. CBET 2445) on Sept. 5 UT by M. Calkins
with the F. L. Whipple Observatory 1.5-m telescope (+ FAST). Cross-
correlation with a library of supernova spectra using the "Supernova
Identification" code (SNID; Blondin and Tonry 2007, Ap.J. 666, 1024) shows
that both 2010hk and 2010ho are normal type-Ia supernovae at a few days past
maximum light.
2010 September 6 (CBET 2447) Daniel W. E. Green
6 September 2010
IAU Electronic Telegram No.2448
APPARENT NOVA IN M31: M31N 2010-09a
Syuichi Nakano, Sumoto, Japan, reports the discovery by Koichi Itagaki
(Teppo-cho, Yamagata) of an apparent nova (mag 17.2) in M31 on unfiltered CCD
frames (limiting magnitude 20.5) taken on Sept. 4.552 UT using a 0.60-m f/5.7
reflector (+ Bitran BT-214E camera). The new object is located at R.A. =
0h42m23s.32 +/- 0s.03, Decl. = +42o17'08".6 +/- 0".3 (equinox 2000.0).
Additional magnitudes for M31N 2010-09a measured by Itagaki: 1986 Nov. 27,
[21.0 (Digitized Sky Survey red plate); 2007 Oct. 13, 20.0; 2010 Aug. 21.631,
[19.0; Sept. 1.666, 17.8 (pre-discovery); 5.490, 18.1 (limiting mag 20.5).
The discovery image is visible at http://www.k-itagaki.jp/images/pn-m-31.jpg.
Nakano also forwards a confirming report by T. Yusa (Osaki) on Sept. 5.500,
in which an unfiltered CCD image taken with a 0.30-m f/9.9 Cassegrain telescope
(+ BSTL-1001E camera) shows M31N 2010-09a at mag 17.5 and with position end
figures 23s.29, 08".9.
2010 September 6 (CBET 2448) Daniel W. E. Green
9 September 2010
IAU Electronic Telegram No.2449
(CfA), on behalf of the CfA Supernova Group, report that a spectrum (range
340-740 nm) of 2010hp (cf. CBET 2446) was obtained on Sept. 8 UT by P. Berlind
with the F. L. Whipple Observatory 1.5-m telescope (+ FAST). Cross-correlation
with a library of supernova spectra using the "Supernova Identification" code
(SNID; Blondin and Tonry 2007, Ap.J. 666, 1024) shows that 2010hp is a type-II
supernova more than 30 days past maximum light.
2010 September 9 (CBET 2449) Daniel W. E. Green
Сообщение Tikhon » 07 дек 2010, 13:08
9 September 2010
IAU Electronic Telegram No.2450
SUPERNOVA 2010hq IN UGC 3691
L. A. G. Monard, Pretoria, South Africa, reports his discovery of an
apparent supernova (mag 15.2) on an unfiltered CCD image taken on Sept. 8.136
UT at the Bronberg Observatory. The new object, which was confirmed at mag
15.3 on Sept. 9.136, is located at R.A. = 7h08m03s.35, Decl. = +15o11'10".0
(equinox 2000.0), which is 29" east and 25" north of the galaxy core of UGC
3691. Nothing is shown at this position in Digitized Sky Survey images
(limiting red mag 20.5).
2010 September 9 (CBET 2450) Daniel W. E. Green
11 September 2010
IAU Electronic Telegram No.2451
SUPERNOVA 2010hr IN MCG +07-13-6
Grzegorz Duszanowicz, Akersberga, Sweden, reports his discovery of an
apparent supernova (mag 16.8) on co-added unfiltered CCD photographs (limiting
mag 18.3) taken on Sept. 8.093 UT with a 0.32-m f/3.1 reflector (+ Starlight
Xpress MX716 CCD camera). The new object, which was confirmed at mag 16.5
on co-added images taken on Sept. 10.07 and 10.09, is located at R.A. =
6h07m59s.00, Decl. = +39o15'54".4 (equinox 2000.0), which is 12".5 east and
5".8 south of the center of the galaxy MCG +07-13-6 (= PGC 18452). Nothing is
visible at this position on his co-added images taken on 2008 Oct. 6.96, Nov.
1.97, Dec. 23.79, and 2010 Feb. 7.77 (limiting mag 18.3). An image of 2010hr
has been posted by Duszanowicz at the following website URL:
http://moonbase.be/html/gallery/sncand/ ... TACK-3.jpg.
2010 September 11 (CBET 2451) Daniel W. E. Green
11 September 2010
IAU Electronic Telegram No.2452
G. H. Marion, Harvard-Smithsonian Center for Astrophysics (CfA), on
behalf of the CfA Supernova Group, report that a spectrum (range 340-740 nm)
of 2010hq (cf. CBET 2450) was obtained on Sept. 10 UT by P. Berlind with the
F. L. Whipple Observatory 1.5-m telescope (+ FAST). Cross-correlation with a
library of supernova spectra using the "Supernova Identification" code (SNID;
Blondin and Tonry 2007, Ap.J. 666, 1024) shows that 2010hq is a type-IIp
2010 September 11 (CBET 2452) Daniel W. E. Green
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 32
